surface contouring
Randy Hills
rhills at snow.nohrsc.nws.gov
Thu Feb 23 16:24:34 EST 1995
On Thu, 23 Feb 1995 Rick.Collins at CCIW.ca wrote:
> I was wondering if there is a method of creating a surface contour from an
> elevation site list within a restricted boundary. When using s.surf.idw,
> a raster for the entire geographic region is created. I would like to
> to create a surface within the confines of an irregular political boundary.
> I would appreciate any suggestions that you might have in solving this
> problem.
> Rick
Try creating a raster representing this boundary, and turn this raster into
a mask. s.surf.idw will use the mask to create a surface inside the
boundary. If your boundary is described as a vector, you'll need to use
v.to.rast to create this raster.
Randy Hills, National Operational Hydrologic Remote Sensing Center (NOHRSC)
National Weather Service
Minneapolis, MN
