Command Line Lists...
Amy Keeley
akeeley at ncdc.noaa.gov
Mon Feb 6 13:32:23 EST 1995
Hello,
I am writing an interface to
GRASS with the combined uses
of a C program and some shell
scripts. What I would like to
do is present the interface
user with a list of currently
available region files. Is there
a way to produce a list of files
using the command line parameters?
This could also be used for d.rast,
d.vect, etc. It would seem that
something like:
g.region region=list
would work. It doesn't. I probably
will just do a unix
"ls /$GISDBASE/$LOCATION/$MAPSET/windows"
but I was wondering if there is
another way within GRASS.
Thanks in advance,
Amy Keeley
