Asci vect files from GPS
Carla Elenz
grayling!celenz at uxc.cso.uiuc.edu
Fri Feb 10 15:31:28 EST 1995
Just an addition to Louis Clarke's note regarding importing
ascii vector files from TRimble GPS into GRASS. I have found
that trimble exports the coordinates as easting northing
whereas grass expects it's ascii files to be northing easting.
Also, if your base station runs on a dos PC as ours does, the
file is in DOS text. I run the *.vec file from Trimble through
dos2unix and an awk script to reverse the coordinates before
running v.in.ascii.
Carla Elenz
Camp Grayling, MI
elenz at osiris.cso.uiuc.edu
