r.weight
DUNN JEREMY SIMON dunnj at polarbear.colorado.edu
Fri Feb 17 13:16:46 EST 1995
Good Morning,
I'm trying to overlay a county boundary file to NDVI map using r.weight.
r.weight seems to be having problems withthe syntax I am using. r.weight help
doesn't seem to help. Is ther another way to overlay county line to maps/images
Thanks
Jeremy
P.S> r.weight tells me
weight: assign p09ndvi.imgtest 0 map
What?  Type help for help (syntax error)
weight: weight:
assign <name> <cat> <val>         assign <val> to <cat> for map <name>
I believe my syntax is correct ?
