Tarek Sadek,
             The problem is probably, as you were thinking, that you have not
attributed the lines.  Get into v.digit, chose "L" for label, and assign some
category numbers.  If you don't need more than one category number, you can
bulk label them.  Do a v.support just to make sure, then v.to.rast.
                                 I hope this helps you,
                                                         Mark Caldwell
