connecting sites with lines
Grass package
grass at sun1.bham.ac.uk
Wed Jan 18 05:12:00 EST 1995
> Does anyone know how to make grass connect sequential sites with lines?
> (ie. connect the dots).
> Thanks in advance,
> Rhett
This should be very easy. The site list will be formatted thus:
x|y|#z (or y|x|#z, I forget which)
The vector file should be formatted:
L 3
x y
x y
x y
So if you write a script that takes x and y from the site list, places
them in a new vector formatted file, counts the number of lines, and
puts L # at the top, you're halfway there. You will need a header,
which is best created by v.out.ascii'ing some vector map and scavenging
its header, and you will need to reconvert the result to binary vector
format using v.in.ascii. I do hope you know how to write Unix shell
scripts...
Martijn van Leusen
