grass to MapInfo and vice-versa
Xin Zhuang
zhuang at access.digex.net
Tue Jan 24 09:35:52 EST 1995
From grass-lists-owner at max.cecer.army.mil Tue Jan 24 04:25:31 1995
Received: from ginko.cecer.army.mil by nfs2.digex.net with SMTP id AA23008
(5.67b8/IDA-1.5 for <zhuang at access.digex.net>); Tue, 24 Jan 1995 04:25:29 -0500
Received: (from daemon at localhost) by ginko.cecer.army.mil (8.6.9/8.6.9) id CAA11021 for grassu-people; Tue, 24 Jan 1995 02:30:27 -0600
Received: from max.cecer.army.mil (max.cecer.army.mil [129.229.20.254]) by ginko.cecer.army.mil (8.6.9/8.6.9) with ESMTP id CAA11018 for <grassu-list at ginko.cecer.army.mil>; Tue, 24 Jan 1995 02:30:25 -0600
Received: from xs1.xs4all.nl (motte at xs1.xs4all.nl [193.78.33.42]) by max.cecer.army.mil (8.6.9/8.6.9) with SMTP id CAA19073 for <grassu-list at max.cecer.army.mil>; Tue, 24 Jan 1995 02:29:39 -0600
Received: by xs1.xs4all.nl id AA17390
(5.67b/IDA-1.5 for grassu-list at max.cecer.army.mil); Tue, 24 Jan 1995 09:29:46 +0100
Message-Id: <199501240829.AA17390 at xs1.xs4all.nl>
Subject: Re: grass to MapInfo and vice-versa
Sender: grass-lists-owner at max.cecer.army.mil
Reply-To: grassu-list at max.cecer.army.mil
Precedence: Bulk
Date: Tue, 24 Jan 1995 09:29:46 +0100 (MET)
In-Reply-To: <950123124126_100074.213_EHK55-1 at CompuServe.COM> from "National Centre" at Jan 23, 95 07:41:27 am
X-Mailer: ELM [version 2.4 PL21]
Content-Type: text
Content-Length: 884
Status: R
> Hello,
> Has anybody had any experience of exchanging vecter data between MapInfo
> and Grass - is there a good way of retaining attribute data?
> Cheers, Al.
Afaik there is no code around that does the trick. I spent a few hours
trying to make a conversion program, but it's not that easy given
MapInfo's vector data structure (any volunteers?). The best way so far is
to use DXF layers, but this means you'll have to export each attribute in
a separate layer.
Philip Verhagen
P.S. Next time you put a message on the list, it might be a good idea to
add your full name, affiliation and e-mail adress...
S t i c h t i n g R A A P
Regionaal Archeologisch Archiverings Projekt
adress: Plantage Muidergracht 14
1018 TV Amsterdam
THE NETHERLANDS
phone: (31) 20 525 5835
fax: (31) 20 525 5834
e-mail: motte at xs4all.nl
I wrote v.in.mapinfo but won't get back to you until
late this week. Please email me directly.
v.out.mapinfo can be done. However, MapInfo makes its projection
line not that easy to be accesses. There's a projection file
come with MapInfo. However, you probably notice that
they're different when included in MIF (MapInfo Interchange Format)
files. I guess it needs to sit down for a while and study them
before writing v.out.mapinfo. The easiest way is probably
to create a lookup table for all UTM in the US.
--Xin
