grass4.1 on HP9000/715 9000/715
E.A. Koster ekoster at let.rug.nl
Wed Jan 25 04:10:39 EST 1995
In article <199501180911.DAA05136 at max.cecer.army.mil>, you write:
> I finally succeeded in downloading the grass4.1 source via ftp and then
> wanted to compile. As everybody knows, this may cause a lot of problems
> and so it did. Also I have to compile such a huge complex of programms for
> the first time so that the few hints given in the grass4.1 installation guide
> are not enough information to be successful within reasonable time.
> Therefore I would like to ask if there is amybody out there, who has
> binaries of grass4.1 to be used on my HP 9000/715 machine or knows if those
> exist and where to get them. Furthermore (in case I will have to compile) I
> would bevery happy to know someone to frequently pose questions to in order to
> be able to realize the compilation.
> Thank you all in advance for your help,
> regards,    Bernd HEBEL
>  bernd hebel					    {:-)_____]
>  universitaet fuer bodenkultur
>  institut fuer hydraulik und landeskulturelle wasserwirtschaft
>  a-1190  wien, nussdorfer laende 12
>  austria - europe
>  bernd at hydra.boku.ac.at
Bernd,
On moon there should be a file HP.trouble.shooting from Nalneesh Gaur (ngaur at apwk01g3.abrfc.noaa.gov), but there should also be a compiled version of Grass4.1 for HP on a ftp-site
But if you can't get it elsewhere you can get a copy here.
Elwin
