d.colors- can you use an input file
    Rick Thompson
    rick at cast.uark.edu
    Thu Jan 26 11:48:00 EST 1995
  If you want to use an input file, then you can "cat file | r.colors rastermap
c=rules" . "file" contains your color rules, "rastermap" is the raster layer to
which you're applying the rules. There are several ways to construct the color
rules file that you can find under the manual entry. It's easy.
> >As a side note, can d.colors take an input file instead of needing a
> >user to go in for each raster file and manually switch RGB values?
Rick Thompson-   Research Specialist          E-mail: rick at cast.uark.edu
Center for Advanced Spatial Technologies      Telephone: (501) 575-8498
Ozark Hall Rm. 12                             Fax: (501) 575-5218
University of Arkansas
Fayetteville, AR 72701
