bugs in v.report?
Xin Zhuang zhuang at access.digex.net
Fri Jan 27 11:51:13 EST 1995
Here is the patch:
*** do_v_stats.c	Fri Jan 27 11:47:34 1995
--- do_v_stats.c.new	Fri Jan 27 06:35:56 1995
*** 35,41 ****
  	int nArea, nLine, map_type, v_r;
! 	int cnt=0, cat_no, line, linea, island;
  	int first, tot_cats, n_points, cmp();
  	register int area_num, line_num, i, ii, jj, kk;
  	char *calloc(), *label_name, null[1];
--- 35,42 ----
! 	int cnt=0, line, linea, island;
! 	CELL cat_no;
*** 119,134 ****
  			/* get the category number for area "area_num" */
  			cat_no = Map.Att[Map.Area[area_num].att].cat;
  /*fprintf(stderr,"\ncat#= %d\n",cat_no);*/
! 			label_name = G_get_cat(cat_no, cats);
  			/* Calculate polygon area */
  			V2_get_area(&Map,area_num,&Areas);
! 			Vect_get_area_points(Map, area_num, Points);
  		        f_area = G_area_of_polygon(Points->x,
  					       Points->y, Points->n_points);
  			/* dig_find_area2(&Map,Areas,&f_area);*/
- 			tot_area = f_area;
  			  /* if this area contains islands remove the
  			    island areas */
--- 120,134 ----
! 			label_name = G_get_cat(cat_no, &cats);
! 			Vect_get_area_points(&Map, area_num, Points);
  			    island areas */
*** 142,152 ****
  			     if (f_area > 0) tot_area = tot_area - f_area;
  			     else tot_area = tot_area + f_area;
! 			     Vect_get_isle_points(Map, Map.Area[area_num].isles[ii], Points);
  			     f_area = f_area - G_area_of_polygon(Points->x,
  			if (first)
--- 142,153 ----
! 			     Vect_get_isle_points(&Map, Map.Area[area_num].isles[ii], Points);
+ 			tot_area = f_area;
  			if (first)
