d.vect floating point error
    DUNN JEREMY SIMON
    dunnj at polarbear.colorado.edu
    Fri Jan 27 13:28:37 EST 1995
Good Morning,
I'm trying to run d.vect in Grass4.1 on an Alpha. OSF v1 1.3, 2.0 . I keep
running into a problem with a floating point error when trying to display
an example file "fields, roads, quads" etc in spearfish database.
Initializing [fields] ...Plotting .... Floating exeception (core dumped)
Has anyone experienced this problem before ? Is this a pointers problem ?
If so where a good placeto start to rectify the problem.
Running d.rast works fine.
Thanks
Jeremy
