r.poly and attributes
Carla Elenz
elenz at osiris.cso.uiuc.edu
Fri Jul 28 13:40:58 EDT 1995
> Susan Huse writes:
> > I just ran an r.poly -l on a VERY large raster file
> > The vector file has 29563 areas but 38100 atts.
> > There should be no labeled lines. I got bazillions
> > of WARNING double labeled, all seem to the same label,
> > so there is no att value conflicts. I suspect that
> > I have approximately 38100-29563=8537 double labels.
> > Do we know why r.poly overlabeled, and how I can
> > get rid of the extras?
> No, I don't know WHY r.poly does this, but I know it does.
> Getting rid of the labels however is very simple: go into v.digit
> and change something (like killing one label). Then exit, and answer yes
> on the question if you want to compress the attributes file. The next
> time you run v.support there should be no more double labels. (This is
> not in the manual; I put a similar question on the list last year and got
> this answer).
> Hope this helps,
> Philip Verhagen
> S t i c h t i n g R A A P
> Regionaal Archeologisch Archiverings Projekt
> adress: Plantage Muidergracht 14
> 1018 TV Amsterdam
> THE NETHERLANDS
> phone: (31) 20 525 5835
> fax: (31) 20 525 5834
> e-mail: motte at xs4all.nl
If the double labels are not the same (ie, if a new label was
added on top of another) does it keep the last and presumably
correct label?
Carla Elenz
Camp Grayling, MI
