bi-linear interpolation from a coarser to finer grid
James Darrell McCauley
mccauley at ecn.purdue.edu
Fri Jul 28 14:54:27 EDT 1995
Eric Small (esmall at rupture.ucsc.edu) writes on 26 July 1995:
>does anyone know how to bi-linearly interpolate from a 7:30 x 4:30 (degrees) raster
>to a 2 X 2 (degree) raster ??
Here's one way (off the cuff, untested):
# change resolution
g.region res=2
# get cell coordinates
r.stats -1g oldmap | s.in.ascii junk
# sample "oldmap" at these coordinates
s.sample -B i=junk o=newmap rast=oldmap
# change the format of the sites list "newmap"
s.out.ascii -d newmap | awk '{printf "%s %s #%d $1,$2,,$3}' \
| s.in.ascii junk
# convert "junk" sites to raster "newmap"
s.menu
# clean up
g.remove sites=junk,newmap
s.sample may be found at
ftp://pasture.ecn.purdue.edu/pub/mccauley/grass/s.sample.tar.gz
s.sample will also do cubic convolution.
However, if you'd like to use something better than bilinear,
r.resample.tps may meet your needs.
ftp://moon.cecer.army.mil/grass/incoming/interp_lib.tar.Z
Darrell
James Darrell McCauley, PhD http://soils.ecn.purdue.edu/~mccauley/
Agricultural & Biological Engineering mccauley at ecn.purdue.edu
Purdue University tel: 317.494.1198 fax: 317.496.1115
