s.surf.tps
mike at ce.umanitoba.ca
Thu Jun 15 08:00:00 EDT 1995
> Hello!
> I want to built a DEM using s.surf.tps from a contour lines map
> and some reference heights I digitized before. The result of this process
> is quite nice ussually. But my problem now is that I'm working in a very
> flat area. The contour interval in the maps I vectorized was of 10 metres.
> So, in the flatest zone I may have more than 1 square kilometre without
> any data. I thought I could improve the DEM if I could use streams and
> rivers as topographic data, I mean forcing s.surf.tps to consider that
> stream cells are in lower heights than their neighbors.
> Is this possible in s.surf.tps?
> Is this possible in any other interpolation algorithm in Grass?
> Xavier Ros
> Unitat de Geodinamica Externa i d'Hidrogeologia
> Universitat Autonoma Barcelona
> e-mail: xavi at cataw.uab.es
Xavier,
I didn't notice if anybody has responded to your notice. Hopefully this will h
elp.
I have been through the same thing with flat areas. I did not like the results
from s.surf.tps. I think s.surf.contour will do a good job for you, especiall
y since your area is flat. The only problem is that it may take a very long ti
me to run since there are large open areas with no data. Any additional elevat
ion information you can give it would be beneficial.
__________________________________________________________________
Mike Bender
Facility for Intelligent Decision Support in Water Resources
Civil & Geological Engineering
University of Manitoba
Winnipeg, Manitoba, R3T 2N2, CANADA
(204) 474-6746 [phone]
(204) 261-9534 [fax]
mike at fids.ce.umanitoba.ca
