Why are r.patch'ed files so slooowwww?
Teresa Hansen teresa at lewis-deh2.army.mil
Tue Jun 27 13:24:33 EDT 1995
This is not much consolation but try using r.resample on the file.
I've found it helps.  I have no idea why this happens unfortunately.
Good Luck
Teresa Hansen
Ogden Professional Service
Fort Lewis, Washington USA
> From grass-lists-owner at moon.cecer.army.mil Tue Jun 27 09:54:53 1995
> From: S.Cox at solo.ned.dem.csiro.au (Simon Cox)
> Subject: Why are r.patch'ed files so slooowwww?
> I have a bunch of not-large rasters (240rx360c) which tile together to
> cover a much larger area.  I thought it would be useful to use r.patch to
> stitch these together so I could subset it just using g.region, etc.
> However, when I d.rast the resultant file it is soooo slooowwww it is not
> funny.  I can display _all_ the tiles in a much much much shorter time.
> What is the story here?  any ideas?
> (I have tried 9-at-a-time, 4-at-a-time, 2-at-a-time, always being careful
> to set the region to exactly cover the contiguous area only, but horrible
> performance in all cases.)
> Thanks for your suggestions.            Simon Cox
> ___________________________________________________________
> Dr Simon Cox                          __  \
> CSIRO Exploration & Mining         ,~'  L_|\    Australian
> 39 Fairway, PO Box 437,         ;-'         \   Geodynamics
> Nedlands, WA  6009  Australia   (            \  Cooperative
>       Phone +61 9 389 8421      +    ___     /  Research
>       Fax   +61 9 389 1906       L~~'   "\__/   Centre
> simon at ned.dem.csiro.au                     W
> AGCRC info>>   http://www.dem.csiro.au/simon/crc/intro.html
