Memory problem s.surf.tps
Irina Kosinovsky
irina at diego.cecer.army.mil
Mon Mar 13 13:47:49 EST 1995
In info.grass.user you write:
>Hi all,
>a presumably simple question for any UNIX guru among you: after running
>s.surf.tps on a relatively large set of elevation points, the program
>exits after reaching 100% with the message
>ERROR: G_calloc: out of memory
>Can anybody tell me what kind of memory I should free in order to
>prevent this problem? The program warned me that I needed about 34Mb
>diskspace for temporary files, but I still have 76Mb free on the disk
>that the files are supposed to be written AFTER the program finished - is
>this simply not enough, and if so, why? There is 34 Mb of files present
>in the $LOCATION/.tmp/[hostname] directory. I suppose these are the
>files that are eventually written out as the desired GRASS raster files
>- can I salvage these by transferring them to $LOCATION/cell and run
>r.support? Any help is greatly appreciated!
>Philip Verhagen
> S t i c h t i n g R A A P
> Regionaal Archeologisch Archiverings Projekt
>adress: Plantage Muidergracht 14
> 1018 TV Amsterdam
> THE NETHERLANDS
>phone: (31) 20 525 5835
>fax: (31) 20 525 5834
>e-mail: motte at xs4all.nl
To get rid of this problem you might want to get the new version of
s.surf.tps. It is a part of interp.shar.Z file on moon.cecer.army.mil
(/grass/incoming directory)
When you get it, just "unpack" it and there will be 5 directories
including s.surf.tps. You will need to run gmake4.1 in all of them starting
with /tree and /data
Email me if you have any questions
Irina
__| \ / |__
_ o ___\o \o | o/ o/___ o _
/\ /) | ( \ /o\ / ) | (\ /\
___|_\______irina at zorro.cecer.army.mil_____/_|__
