more mayday (m'aidez) our monitors are sick
Ken Sibley
ksibley at ncg.nrcs.usda.gov
Fri Mar 10 10:12:46 EST 1995
> Thanks to all who replied to my message. As far as I know we
> are still using the fifo version of GRASS. We are running
> grass (not xgrass) on solaris2.3. The ipcs -aq command returned
> hawaii% ipcs -aq
> IPC status from <running system> as of Fri Mar 10 09:49:01 1995
> Message Queue facility not in system.
> hawaii%
> I followed David Houlders second suggestion of rebooting and that
> seems to have done the trick, some nuts require sledge hammers
> I guess (particularly with my level of unix expertise!)
> I'm still curious as to why this "epidemic" started.
> Thanks again
> Tom 8-)
We have seen these type of problems occassionaly. Usually it is
caused by the graphics monitor while the mouse is active; ie. while
using d.what.rast or some other mouse command. Our only solution
also has been to reboot the machine. This has happened to us
on 3 different platforms: 1)AT&T SYS V Rel 3.2.x Unix on 386/486
2)Sun Sparc stations with SunOS 4.1.x 3)Unixware 1.x on 486.
Ken Sibley
USDA-NRCS/NCG "Hell, if you understand everything I say,
ksibley at ncg.nrcs.usda.gov you'd be me!" - Miles Davis
