Memory problem s.surf.tps
Pat McClanahan
mcclanah at dlgeo.cr.usgs.gov
Fri Mar 10 09:07:48 EST 1995
On Thu, 9 Mar 1995, Peter Mikes wrote:
> ----- Begin Included Message -----
> ERROR: G_calloc: out of memory
> Can anybody tell me what kind of memory I should free in order to
> e-mail: motte at xs4all.nl
> ----- End Included Message -----
> This is not the same as ' disk full ' message. Ask your system
> administrator to increase your 'swap space' so that your virtual
> memory ( which looks like RAM to program) can handle the large arrays
> Hope this helps ----- Peter
Boy - I haven't run GRASS for a couple of years now, but I remember
seeing this message when we created data on a system that was big endian
and then attempted to read that file on a little endian machine (or vice
versa). Because the bits are now backwards you system is attempting to
allocate some outragoues amount of memory.
Not a GRASS guru - just my thoughts.
Pat McClanahan Internet:mcclanah at dlgeo.cr.usgs.gov
EROS Data Center mcclanah at edcserver1.cr.usgs.gov
Sioux Falls, SD
605-361-4607
