land area on sloping surfaces
Stephen B. King
sbk at apwk01g3.abrfc.noaa.gov
Fri Mar 10 13:56:51 EST 1995
> > In mountainous terrain on a sloping surface the planimetric land area
> > is less than the actual surface area on the ground. Is there an easy
> > way to use a DEM in GRASS to find the actual surface area? Maybe I'm
> > asking for a 3-D GIS...
> > Bill
> > bakerwl at uwyo.edu
> Interesting problem. It should be possible to use r.mapcalc to look for four
> neighboring DEM measurements, calculate distances and angles along the
> surface between them, and the surface area of the enclosed lozenge from
> that. This would create a new map, which can then be used to derive
> aggregate surface measurements a la r.average.
> Martijn
> p.m.van-leusen at bham.ac.uk
I missed the original thread, and perhaps I don't understand the problem,
but I would think that area of a sloping cell could be found by:
(CELL WIDTH)^2/cos(slope)
r.average would then do the rest.
Steve King
Hydrologist 10159 East 11th St., Suite 300
NOAA, National Weather Service Tulsa, Oklahoma 74128-3050
Arkansas-Red Basin River Forecast Center Off: (918)832-4109
sbk at awips1.abrfc.noaa.gov FAX: (918)832-4101
