elevation data
Robert Atnip atnip at osiris.cso.uiuc.edu
Thu Mar 30 13:45:44 EST 1995
> My problem is that I have vector contours that don't seem to have any information telling me what elevation they are!  I am unsure what steps to take to get this information or whether I still have this information.
> I am currently trying to import elevation data (plus some other stuff) from DXF files into grass4.1.  During the import (v.in.dxf) there were WARNINGS about 3d data, which GRASS cannot accommodate.  I may have lost the elevation data for the contours then, or maybe not!  The map information comes from NTS maps from the Ministry of Natural Resources in Canada.  They are 1:50000 UTM with 10m intervals on the contours.  Hopefully, it will be possible to fix the contour information without manually entering elevation data for thousands of lines.
> What is the procedure for converting vector contour lines into a DEM in GRASS?
> Mike Bender
> Facility for Intelligent Decision Support in Water Resources
> Department of Civil & Geological Engineering
> University of Manitoba
> Winnipeg, CANADA
