Grass and DEC-Alpha
Wilhelm Hagg
hagg at ipf.bau-verm.uni-karlsruhe.de
Wed Nov 1 07:00:00 EST 1995
mark robbins said:
>>Did anyone of you use the ppm - Driver to generate Map
>>outputs with p.map or p.map.new ?
>>That didn't work, I'm still looking for the bug.
>I'd be interested in knowing the answer to this also. Although I don't
>know what problem Wilhelm was having, on my Sparc 20 with Solaris 2.4 I
>keep getting the error:
>ERROR: ppm driver: unable to create lock
>ERROR: can't read from ppm driver
I also had the problem
the lock problem i don't have, because i plot to file. I think
it's the same problem.
Here is what i found:
the applib library, located in $(GIS)/src/paint/Interface/applib
contains the file device.c
It contains the function
P__readdev (buf, n)
char *buf;
But no specification for the type of "n"
the "read" function-call is done there with "n" as argument, and
n seems to be an integer. Also the return-value of the read function
is assigned to an integer. On Dec-Alpha the "n" - Argument to read
is of type "unsigned long" and the read-function returns a long.
Maybe this is the reason for the problem. I didn't check it so far,
because i dont have always access to the DEC-Alpha machine.
Bye ..
Wilhelm Hagg, Institute of Photogrammetry and Remote Sensing
Karlsruhe University, Englerstr. 7, D-76128 Karlsruhe
Phone: +49 721 608 4131, Fax: +49 721 69 45 68
Email: hagg at ipf.bau-verm.uni-karlsruhe.de
WWW: http://www-ipf.bau-verm.uni-karlsruhe.de/Personen/hagg/hagg.html
