measuring area
    Joe Leone
    Joe.Leone at per.dwe.csiro.au
    Mon Oct 16 08:00:00 EDT 1995
> From grass-lists-owner at moon.cecer.army.mil Fri Oct 13 17:42 WST 1995
> From: motte <motte at xs4all.nl>
> Message-Id: <199510130834.AA21944 at xs1.xs4all.nl>
> Subject: Re: measuring area
> Sender: grass-lists-owner at moon.cecer.army.mil
> To: grassu-list at max.cecer.army.mil
> Date: Fri, 13 Oct 1995 09:34:01 +0100 (MET)
> X-Mailer: ELM [version 2.4 PL21]
> Content-Type: text
> Status: RO
> > Hi all,
> >     I have a situation in which I am trying to extend (grow) the area of a
patch in a particular direction, depending on the ajacent cell. I want the patc
h to grow only untill it gets to a specified size ( say 20 Hectares). The troub
le I have is stopping t
 he>  growth.
> > I have managed to get the patch to grow by identifying potential growth are
as and runing the script below
> > I would appreciate any suggestion.
> > Thanks Joe
> > raster map test.g has three categories
> > cat value   cat label
> > 0           potenial growth
> > 5           non growth
> > 999         patch value
> > #!/bin/csh -f
> > # r.mapcalc script to grow remnant aeras in suitable soil types.
> > @ i=1
> > @ num=10
> > echo $i
> > echo "this will run through "$num, "loops   "
> > d.erase
> > g.copy rast=test.g,output
> > #echo " now using "output.$i--
> > while ($i <= $num)
> > r.mapcalc output.$i = 'if(output,output, eval(if(output[0,-1]==999|| output
[0,1]==999||output[-1,0]==999||output[1,0]==999,999)))'
> > g.copy rast=output.$i,output
> > @ i++
> > echo $i
> > end
> Hi Joe,
> I'm not pretending to have the best answer, but I'll have a try. Area
> measurements in raster maps can be made through r.stats, which will give
> the numbers of pixels contained by each category. You want to have a
> script that tells r.mapcalc not to grow patches that have exceeded a
> certain size. You might try the following: give your patches unique
> values (e.g. with r.clump) and have the mapcalc function assign the values
> of the clumps to the cells that are to be 'stitched' to the patch. Run
> r.stats to see which clumps are now exceeding the size of say 20
> hectares and assign a new value (something like -1 or so) to these areas
> with r.mapcalc. The next time you start the 'grow' function, exlude these
> areas. It's not pretty, but I think it should work; I hope someone can
> think of a quicker solution...
> By the way, what on earth do you need a function like that for?
> Philip Verhagen
>                       S t i c h t i n g  R A A P
>               Regionaal Archeologisch Archiverings Projekt
> adress:       Plantage Muidergracht 14
>               1018 TV Amsterdam
>               THE NETHERLANDS
> phone:          (31) 20 525 5835
> fax:          (31) 20 525 5834
> e-mail:               motte at xs4all.nl
Thanks to all thoses that responded.
I'll answer Philip's question to the list, in case somebody wants/can suggest a
 better prodedure :-)
I am working on a landscape reconstruction project and landuse allocation model
Part of the model is to allocate certain areas of the landscape to convservatio
n.  These areas would probably be ajacent to exsisting vegetation remnants.
I have a soil map and a remnant vegetation map. The soil layer has 15 soil type
s.  The remnant layer has some 30 remnants scattered through out the region, an
d with in those remnants vegetation types (patches) have been mapped. The veget
ation type is associated with soil type.
The idea is to increase the patches of vegetation type to a minimum size by exp
anding to the ajacent area. The restriction is that the area can only grow on t
he assicated soil type.
What I have done is combined these two maps and for each soil type - vegetation
 type combination produced a map of protential growth area. I then run the abov
e script on that map
Thanks Joe
