ps.map, hp650c's and paper wasting
Stuart Bradshaw
stuart.bradshaw at lewis-deh2.army.mil
Thu Oct 5 18:39:47 EDT 1995
There is a shell program at moon.cecer.army.mil called add.pagesize.
This puts in a pagesize command into the postscript file and helps with
the paper waste problem.
The add.pagesize program uses the current ps.select device to determine how
big the the page size should be. So just note those height/width numbers
are the ones used - it is not actually determining this from the postscript
file.
We just set up a hp650c and i hope to work on the add.pagesize script to
have the plotter waste even less paper and make the plotting process basically
"one" step. We'll see. . .
> Kevin Seel writes:
> >When I send a postscript plot to our hp650c using ps.map, the printer
> >happily scrolls our 6 feet or so of expensive paper before it decides
> >to print something. Does anybody have an idea why it does this, and
> >how I can get around it?
> I know - we get the same thing with our HP. Similarly, our xerox versetec type
> with special software seems to think everything is letter size. This occurs
> with several conversion programs, so it's not endemic to ps.map.
> The best I have heard so far is that the postscript file is not produced with
> a fixed size - I do not know if this is true.
> However - I thought (am not sure) that this only occurs if the plotter is in
> HPGL mode and is sent the language conversion command. Is your plotter set
> to default to HGL or to postscript?
> mzk
\_\_\_\_\_\_\_\_\_\_\_\_\_\_\__\_\_\_\_\_ \_\_\_\_\_\_\_
\_ Stuart Bradshaw, Ogden \_ \_ /\_
\_ ATTN: AFZH-DEQ (GIS LAB) \_ \_ /\_\_
\_ Bldg. 4301 Main St. \_ \_ /\_\_\_
\_ Ft. Lewis, WA 98433-5000 \_ \_ /\_\_\_\_
\_ Phone: 206-967-4985 Fax: 206-964-2488 \_ \_ /\_\_\_\_\_
\_ stuart.bradshaw at lewis-deh2.army.mil \_ \_/\_\_\_\_\_\_
\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_ \_\_\_\_\_\_\_
