cat file for r.mapcalc
Xin Zhuang
zhuang at access.digex.net
Mon Oct 16 13:25:31 EDT 1995
I tried with r.patch and found out r.patch mislabel the cats.
I was trying to merge block layers from two counties.
Somehow r.patch assigned some cats crossing counties.
Maybe a bug in r.patch?
I modified r.cross with fs (not reruied). The original
r.cross uses semicolon (;) to separate cats from
dirrerent layers. With fs, you can have many other choices.
Here's syntax
r.cross input=[files....] output=file fs=[character|SPACE|semicolon]
I enclosed a patch at the end of this message.
--Xin
begin 600 patch.cross.tar
M<&%T8V at N8V%T<P``````````````````````````````````````````````
M````````````````````````````````````````````````````````````
M`````````````"`@(#8V-"``("`@,S$Q(``@("`@-C(@`"`@("`@("`@,S,R
M("`V,#0P-3`T,C0P("`@-C`R-P`@````````````````````````````````
M```````````````````````S8S,*/"!S971?8V%T("AR97-U;'0L(&-A="P@
M<&-A=',L(&9S*0HM+2T*/B!S971?8V%T("AR97-U;'0L(&-A="P@<&-A=',I
M"C=D- at H\("`@("!C:&%R("IF<SL*,CDL,S-C,C@*/"`):68@*"!I("8F(&9S
M("D@"CP@"7L@"CP@"2`@<W1R8V%T("AB=68L(&9S*3L@"CP@"2`@<W1R8V%T
M("AB=68L(")<,"(I.R`*/"`)?0HM+2T*/B`):68@*&DI('-T<F-A="`H8G5F
M+"`B.R`B*3L@"@``````````````````````````````````````````````
M`````````````````````````````````````````````'!A=&-H+FUA:6X`
M```````````````````````````````````````````````````````````@
M("`V-C0@`"`@(#,Q,2``("`@(#8R(``@("`@("`@,30V,B`@-C`T,#4P-#(W
M,B`@(#8P-3,`(```````````````````````````````````````````````
M````````-2PV9#0*/"!S=&%T:6, at 9G,])UPP)SL*/"`*,35D,3(*/"`@("`@
M<W1A=&EC(&-H87(@9G,["C,P8S(W"CP@"7-T<G5C="!/<'1I;VX@*FEN<'5T
M+"`J;W5T<'5T+"`J9G,["BTM+0H^(`ES=')U8W0 at 3W!T:6]N("II;G!U="P@
M*F]U='!U=#L*-3<L-C-D-3,*/"`@("`@<&%R;2YF<R`]($=?9&5F:6YE7V]P
M=&EO;B at I(#L*/"`@("`@<&%R;2YF<RT^:V5Y("`@("`@("`](")F<R(["CP@
M("`@('!A<FTN9G,M/FME>5]D97-C("`@/2`B8VAA<F%C=&5R?'-P86-E.G-E
M;6EC;VQO;B(["CP@("`@('!A<FTN9G,M/G1Y<&4@("`@("`@/2!465!%7U-4
M4DE.1SL*/"`@("`@<&%R;2YF<RT^<F5Q=6ER960@("`]($Y/.PH\("`@("!P
M87)M+F9S+3YD97-C<FEP=&EO;CT@(D]U='!U="!S97!A<F%T;W(@8VAA<F%C
M=&5R("AD969A=6QT.B!N;W1H:6YG*2(["CP@"C<W+#@V9#8V"CP@("`@:68@
M*'!A<FTN9G,M/F%N<W=E<B`A/2!.54Q,*0H\("`@("SL*/"`@("`@("`@(&5L<V4@:68@*'-T<F-M
M<"AP87)M+F9S+3YA;G-W97(L(")S96UI8V]L;VXB*2`]/2`P*0H\("`@("`@
M("`@("`@(&9S(#T@)SLG.PH\("`@("`@("`@96QS90H\("`@("`@("`@("`@
M(&9S/2!P87)M+F9S+3YA;G-W97);,%T["CP@("`@('T*/"`*,3 at P8S$V,`H\
M(`ES971?8V%T("AN8V%T<RP@<F5C;&%S<UMN8V%T<UTN8V%T+"`F<&-A=',L
M("9F<RD["BTM+0H^(`ES971?8V%T("AN8V%T<RP@<F5C;&%S<UMN8V%T<UTN
M8V%T+"`F<&-A=',I.PH`````````````````````````````````````````
end
