Hi folks... I was wondering if someone has a problem with v.proj. When I try to v.proj a vector map with an attribute file from Mercator projection to Lat/Long projection, it drops off a few attribute lines. Any ideas on what conditions must be met in order to make v.proj works !! Thanks
