d.mon in Solaris
Christine Gemuend
christin at info.estec.esa.nl
Tue Sep 19 08:00:00 EDT 1995
> When I exit from GRASS without stopping graphics monitor next time when
> I try to start graphics monitor I get the following message:
> 1
Enter name of graphics monitor to start
Enter "list" for a list of known monitors
Enter "list -f" for a list with current status
Hit RETURN to return to menu
> x0
Graphics driver [x0] is already running
Warning - no response from graphics monitor <x0>.
Check to see if the mouse is still active.
ERROR - no response from graphics monitor <x0>.
Problem selecting x0. Will try once more
hit RETURN ->
> What should I do to avoid this problem (except to remember stopping monitor)?
> Best regards,
> Kris Koperski
Hello Kris,
the command
d.mon select=x0
should help you in such case.
Greetings, Christine
