ps.map -> sites -> label problem
Rick Thompson
rick at cast.uark.edu
Wed Sep 27 15:06:19 EDT 1995
On 27 Sep 1995, Kim Dralle wrote:
> With ps.map I want to print sites along with their labels, but without the text framed with squares. Is there an easy way to ommit these squares?
Hi Kim,
You can use labels in ps. See the documentation of ps.map. You can use a
script like below to convert sites to labels.
Rick Thompson- Research Specialist E-mail: rick at cast.uark.edu
Center for Advanced Spatial Technologies Telephone: (501) 575-8498
Ozark Hall Rm. 12 Fax: (501) 575-5218
University of Arkansas
Fayetteville, AR 72701
------------cut here ---------------------------------------------------------
# *** This is s.to.label . ***
# @(#) convert site file to labels file for ps.map.
if [ `uname -m` = mips ] ; then
ECHON="/usr/bsd43/bin/echo -n"
elif [ `uname -s` = SunOS -a `uname -r | sed 's/\...*$//'` = 5 ] ; then
ECHON="/usr/ucb/echo -n"
else
ECHON="echo -n"
fi
if [ -z "$GISRC" ] ; then
clear
echo "This command must be run from GRASS!"
echo ''
exit 1
fi
clear
echo ''
g.ask type=old prompt="Make labels for which site map?" \
element=site_lists desc=site unixfile=/tmp/$$
. /tmp/$$
rm -f /tmp/$$
if [ ! -f $file ]; then
echo "Site map $name not found."
echo ''
exit
fi
echo ''
$ECHON "Size: "
read size
echo ''
echo ''
if [ -f $LOCATION/cell/MASK ] ; then
$ECHON 'Remove MASK? (n) '
read ans
if [ "$ans" = "y" -o "$ans" = "Y" ] ; then
g.remove rast=MASK > /dev/null
else
echo ''
$ECHON 'Want to zoom in on the MASK? (y) '
read ans
if [ "$ans" = "y" -o "$ans" = "Y" -o -z "$ans" ] ; then
g.region rast=MASK z=MASK
fi
fi
fi
echo ''
$ECHON 'Mask the points (n) '
read ans
r.mask.points mask=MASK input=$file fs='|' \
> $LOCATION/site_lists/tmpsite.mask
file=$LOCATION/site_lists/tmpsite.mask
fi
fi
cat $file | sed '/name/d' | sed '/desc/d' | awk '
FS="|"
printf("east: %f\n",$1)
printf("north: %f\n",$2)
printf("xoffset:\n")
printf("yoffset:\n")
printf("ref: center\n")
printf("font: helvetica\n")
printf("color: black\n")
printf("size: '$size'\n")
printf("width: 1\n")
printf("hcolor: white\n")
printf("hwidth: 2\n")
printf("background: none\n")
printf("border: none\n")
printf("opaque: no\n")
printf("\n")
printf("text:%s\n",$3)
printf("\n")
}' > $LOCATION/paint/labels/$name
if [ -f $LOCATION/site_lists/tmpsite.mask ] ; then
rm $LOCATION/site_lists/tmpsite.mask
fi
