importing DEM's
Scott Grover
ScottG at horne.com
Mon Apr 29 08:00:00 EDT 1996
I am using GRASS 4.15 under Linux. I downloaded some DEMs from the USGS,
but it appears that the existing extraction utilities in GRASS are expecting
the files to be on tape. When I copy the files to a tape, m.dem.extract
fails to create a proper raster map. It repeats the error message that the
program unexpectedly encountered a type C header file, but then continues
with the file processing. It also appears that the DEM does not have the
proper UTM coordinates. The USGS spec sheet for the 1-degree DEM says the
coordinate system is "World Geodetic System 1972 Datum." The units apear to
be in arc-seconds. Will m.dem.extract convert these valuse to DD:MM:SS?
I have copied the DEM to tape, and used m.dem.extract from a variety of
locations and projections (the proper UTM zone, and LL with WGS 1972). Each
time a raster file is created, but GRASS is unable to open these files: "map
does not match projection of current mapset" is the error message.
Does anyone recognize what I am doing wrong, and/or have any suggestions for
creating a raster map from a USGS 1:250K DEM?
Thanks,
Scott Grover
scottg at horne.com
