convert line pts.to nodes
    Philip Verhagen
    philip at raap2.ivambv.uva.nl
    Thu Apr 25 08:00:00 EDT 1996
> Is there a way to convert individual line points to nodes without using
> line definition?
If I understand your problem correctly, probably the easiest way to do it
will be exporting the vector-file to dig_ascii format with v.out.ascii.
The resulting dig_ascii file will contain the lines in the format
L 5
   1000 2000
   1000 1500
   750 1200
   500 1000
   1000 2000
Note that the order of the coordinates is y,x for some unexplained reason.
You can split these lines into lines with just two nodes by writing a
script that performs sed -n ${x}p on the file, checks for the right format
and then writes the lines to a new dig_ascii file, inserting a line with
L 2 for each new two-node line. You can subsequently import the new file
with v.in.ascii. If this doesn't sound clear enough (I've just had
my first coffee), let me know and I'll try to explain it again :)
Philip Verhagen
                              R  A  A  P
                        Plantage Muidergracht 14
                          1018 TV Amsterdam
                           The Netherlands
                        tel: +31 (20) 421 62 00
                        fax: +31 (20) 421 42 90
                http://raap2.ivambv.uva.nl/home_eng.html
