v.proj
Brian Culpepper
brian at cast.uark.edu
Tue Apr 23 08:00:00 EDT 1996
Teresa,
Are you certain ALL information in the PROJ_INFO and PROJ_UNITS
files are correct for both GRASS locations? these files should be
located under the $LOCATION/PERMANENT directory of both the UTM and
the AEA "GRASS Locations"... just a shot from the hip :)
good luck
brian
On Tue, 23 Apr 1996, Teresa Salyer wrote:
> HELP!! I can't get v.proj to work I keep getting an error message that reads
> major axis = 0, or not spec'ed cannot initialize pj.
> I'm trying to take a vector map from utm proj. to aea proj. What am I doing
> wrong??
> Thanks for your help in this matter. Teresa Salyer
> <salyer at tiaer.tarleton.edu>
R. Brian Culpepper Research Specialist
Center for Advanced Spatial Technologies (fax) 501 575-5218
Rm. 12 Ozark Hall 501 575-6159
University of Arkansas brian at cast.uark.edu
Fayetteville, AR 72701 Home Page: http://cast.uark.edu
