importing ARC/INFO files
    James Curry
    jcurry at llnl.gov
    Fri Apr 19 08:00:00 EDT 1996
I have a file that is supposed to be an arc/info file. I'd like to
import it into GRASS. I have tried using v.in.arc but on each attempt
I have received the message:   ERROR: Reading LINES file
Below is the firs 20 lines of the file that I am trying to import.
Can someone tell me what is causing the error?
Thanks.
-Jim
EXP  0 /DATA3/KOFFMAN/PENDERGAST/SITEMAPS/FH_MAPU.E00
ARC  2
         1         1         0         0         0         0         2
 4.4081297E+05 3.6828878E+06 4.4076409E+05 3.6828938E+06
         2         2         0         0         0         0         2
 4.4081328E+05 3.6828893E+06 4.4076581E+05 3.6828950E+06
         3         3         0         0         0         0         2
 4.4101038E+05 3.6827960E+06 4.4096928E+05 3.6828353E+06
         4         4         0         0         0         0         2
 4.4092441E+05 3.6829453E+06 4.4093116E+05 3.6830153E+06
         5         5         0         0         0         0       410
 4.4096928E+05 3.6828353E+06 4.4096906E+05 3.6828355E+06
 4.4096884E+05 3.6828358E+06 4.4096863E+05 3.6828360E+06
 4.4096844E+05 3.6828363E+06 4.4096822E+05 3.6828363E+06
 4.4096800E+05 3.6828365E+06 4.4096778E+05 3.6828368E+06
 4.4096756E+05 3.6828370E+06 4.4096734E+05 3.6828373E+06
 4.4096713E+05 3.6828375E+06 4.4096691E+05 3.6828378E+06
 4.4096672E+05 3.6828378E+06 4.4096650E+05 3.6828380E+06
 4.4096628E+05 3.6828383E+06 4.4096606E+05 3.6828385E+06
 4.4096588E+05 3.6828388E+06 4.4096566E+05 3.6828390E+06
 4.4096544E+05 3.6828390E+06 4.4096522E+05 3.6828393E+06
