r.in.erdas
Malcolm Williamson malcolm at cast.uark.edu
Tue Aug 27 08:00:00 EDT 1996
Mike,
On question 1, the Erdas file must be a version 7.3 image file; it won't
work with older data (I don't know about newer data). If you have access
to Erdas, this isn't a problem, as you can use the Erdas command DPDATA
to convert the imagery to general image binary format, which can be
loaded directly in a GRASS cell directory. The cellhd file can be created
using information gleaned from the Erdas command LISTIT. If the Erdas
output file is multi-band, use the GRASS command i.tape.other to load it.
Good luck!
        -Malcolm
Malcolm D. Williamson - GIS Specialist           E-mail: malcolm at cast.uark.edu
Center for Advanced Spatial Technologies      Telephone: (501) 575-6159
Ozark Rm. 12                                        Fax: (501) 575-5218
University of Arkansas
Fayetteville, AR 72701
On Tue, 27 Aug 1996, Mike Hanratty wrote:
> Has anyone encountered the following problems with r.in.erdas?
> 1. On a Sun (SunOS Release 4.1.3_U1), it cannot properly read the header of t
he
> binary Erdas file.  I get strange values for just about all of the entries.
> 2. On a linux PC (Linux 2.0.11) I get a segmentation fault when entering
> G_close_cell on line 478 of main.c.
> If anyone can provide insight on how to fix either of these two problems (or
> both), I'd greatly appreciate it.
> Michael Hanratty                               Phone: (612) 627-4590
> Dept. of Civil Engineering                            (612) 626-0024
> University of Minnesota                        Fax:   (612) 627-4609
> St. Anthony Falls Laboratory
> Mississippi River at 3rd Ave SE
> Minneapolis, MN 55414
