v.in.arc: some doubts
Pat Luther
pluther at usit.net
Fri Dec 27 11:19:21 EST 1996
Giovanna:
At 10:55 AM 12/27/96 MET, you wrote:
>I'm trying to import arc/info ungenerate files in Grassland using v.in.arc
grass function, but I have some doubts:
>1) where I have to store my arc/info ungenerate files? I mean, can I store
them everywhere if I write the whole path (ex.
c:/grassland/adamello/rivers.lin,..) ?
I am not familiar with GRASSLANDS, but with GRASS, you must put the ungenerate
files in a directory named "arc" in your mapset in order to import them.
do I need to write the file extensions (.lin, .txt, .pol, .lab)? Are these
file extensions rigth?
No, you do not have to add the extensions to the file names.
>Importing line coverage type, I wrote the complete path both with or
without file extensions (.lin for arc/info ungenerate lines file and .txt
for arc/info label-text file) but result is:
>"vinarc: Coverage type = line
>cannot find ARC/INFO lines file (rivers)"
You probably have the file in the wrong place. Make a directory called arc
and put them there. Also, be sure to ungenerate as single precision.
>2) Can the GRASS category column in label-text file be the same that the ID
number column in label-text file ?
Yes.
I offer GRASS support & will send you info on it in a seperate email.
Pat Luther
>Every help is welcome.
>Happy new year to everybody.
>Giovanna Ranci Ortigosa
>e-mail: ranci @quercia.elet.polimi.it
Pat Scarbrough Luther "Your dream is the gift of
AEgis Services Corporation your own soul. But if it's
P.O. Box 160 promise is to be fulfilled,
Clinton, TN 37717 you must turn your eyes from
Phone 423.457.8242 the world of men, and dare
FAX 423.457.8620 to fly among the stars....
Internet pluther at usit.net After all, we are born with
wings". Robert Sexton
