open area lines in closed polygons.
Agustin Lobo alobo at ija.csic.es
Fri Feb 23 07:00:00 EST 1996
HI!
I keep on with problems with this coastlines vector.
Mysteriously, there are closed polygons made up of
edges that are open area lines. Hence, I cannot
label the polygons as areas and get wrong results from
v.cutter.
What can I do to convert these open area lines into
closed area lines? I repeat that the polygon is closed,
all nodes are 2-lines nodes.
Thanks!
Agus
Dr. Agustin Lobo
Instituto de Ciencias de la Tierra (CSIC)
Marti Franques s/n
08028 Barcelona (Spain)
tel. 34 3 330 2716
fax. 34 3 411 0012
alobo at eno.princeton.edu
