ps.map output to eps for PC word processor
Ronald Wiemer RWIEM at archis.nl
Thu Feb 15 07:00:00 EST 1996
ps.map output can not be used in Corel Draw or whatever. Usually
these programs can only import Adobe Illustrator EPS, which
is a postscript dialect. Translating GRASS-postscript into AI-eps
format cannot be done automaticly as far as I can see.
If you want to edit grass maps, I would suggest to export raster
maps as tiff and vector maps as dxf, and assemble the two in
Corel!.
Ronald Wiemer
R.O.B. / Archis
Kerkstraat 1
NL 3811 CV Amersfoort
The Netherlands
Tel: ++ 31 33 4634233
Fax: ++ 31 33 4653235
