My note for compiling GRASS 4.15 on Linux
kang at risca.rs.msu.edu
Wed Feb 14 07:00:00 EST 1996
I got several requests for changes I made in order to compile GRASS 4.15 on
Linux. If you really want to compile GRASS by yourself, please read the
installation documentation available on moon first.
Kang,
Here is my note for compiling GRASS 4.15 on Linux:
Linux - Fixes
- mapdev/v.digit and mapdev/v.digit2
modified set_key.c file - line 30
problem - LINUX is POSIX, so use termios instead of termio
change from
struct termio new_termio ;
struct termio old_termio ;
to
struct termios new_termio ;
struct termios old_termio ;
- mapdev/Vlib - for v.build
modify level_two.c file - line 176
problem - v.support dones't run correctly when building topology
comment out
fclose(map->dig_fp);
map->dig_fp=NULL;
- src/raster/r.combine
modified src/raster/r.combine/cmd/gis_lxcl.l - line 176
problem - yyinput() is for C++, use input() for linux flex
change
while ((achar=yyinput()) != 012)
to
while ((achar=input()) != 012)
- src.alpha/ps.map (10/15/95)
modified src.alpha/ps.map/ps.map/cmd/read_cfg.c
problem - atof() in ANSI C need to inlucde stdlib.h
add the following line in the beginning of read_cfg.c file
#include <stdlib.h>
- src.alpha/mapdev/v.proj
modified main.c - line 27
problem - ctype[3] cause lots of garbage output in dig_att
change
ctype[3]
to
ctype[1]
- src.contrib/CAST/d.vect.cats (10/14/95) - program name is d.vect.cat
modified the plotCat.c file - line 91
problem - pointer mistake
change from
Vect_get_area_points(P_map,a_index,Points);
to
Vect_get_area_points(&P_map,a_index,Points);
- src.contrib/PURDUE/d.linegraph
modified the linegraph.c - line 77
problem - fclose and fopen already declared in stdio.h
comment out
FILE *fclose(), *fopen();
