Undeliverable Message
MAILER-DAEMON at WOOD-VINES.ARMY.MIL MAILER-DAEMON at WOOD-VINES.ARMY.MIL
Wed Feb 7 07:00:00 EST 1996
Sender: grass-lists-owner at moon.cecer.army.mil.
Reply-To: grassu-list at moon.cecer.army.mil.
Precedence: Bulk
To:            <grassu-list at max.cecer.army.mil>
Cc:
Subject:       Re: different locations
Message not delivered to recipients below.  Press F1 for help with VNM
error codes.
        VNM3043:  MR MARK ADAMS at TEC@FLW DCD
VNM3043 -- MAILBOX IS FULL
   The message cannot be delivered because the
   recipient's mailbox contains the maximum number of
   messages, as set by the system administrator.  The
   recipient must delete some messages before any
   other messages can be delivered.
    The maximum message limit for a user's mailbox is
   10,000.  The default message limit is 1000 messages.
   Administrators can set message limits using the
   Mailbox  Settings function available in the
   Manage User menu  (MUSER).
   When a user's mailbox reaches the limit, the
   user must delete some of the messages before
   the mailbox can accept any more incoming messages.
----------------------  Original Message Follows  ----------------------On Wed,
 7 Feb 1996 sw at kreutler.de wrote:
> Hi all!
> I want to know, if it is possible to use GRASS with maps stored at different
> locations.
> because in the file .grassrc there is only one possible line for LOCATION.
> different locations can be different machines in the net to.
> if this is possible, please tell me how to use .grassrc
> hints are welcome too!
> thanx in advance
> Stephan
GRASS will only look to mapsets within your current location and GDBASE.
But - if you really want to look at maps stored elsewhere you can use
symbolic links and nfs mounting to create mapsets in your location that
are stored elsewhere.  Just be careful that the coordinate, zone and
other infomraiton are consistent.  If you are using a UTM zone location,
and have a mapset that is linked to data stored in latlon you will have a
mess.
 Susan Huse         /\       http://www.regis.berkeley.edu/sue
 REGIS       /  \ /    \/  \ /\    sue at regis.berkeley.edu
 University of California  /    /  \ (510) 643-6307
   Berkeley        \      /         \
