HELP: Probl. with v.in.dxf / v.support!!!!
Bill Brown brown at gis.uiuc.edu
Wed Jan 31 07:00:00 EST 1996
Giorgos,
This is an old problem that never got fixed:
> There was a bug in the file src/mapdev/Vlib/level_two.c that existed
> for a short time between update 4 and update 5.  Although it was
> fixed and made it into the update_package 5, at the time the
> s5.cpio* files were created, the bug was still there.  So a diff
> on the file included in the update_package vs. the file in the s5*
> source results in:
> 176,177d175
> <       fclose(map->dig_fp);
> <       map->dig_fp=NULL;
> If they downloaded the s5* source, the bug is still there, but if
> they applied the update_package, they should be OK.  I assume the
> binaries should be OK since they were probably done after the
> source & update package, but haven't tried them.
The fix:
download the file ftp://moon.cecer.army.mil/grass/incoming/level_two.c
and replace your src/mapdev/Vlib/level_two.c
Then recompile Vlib and v.build
- Bill
