s.surf.tps problem
ov83609
ov83609%suncc3 at diego.cecer.army.mil
Wed Jan 31 07:00:00 EST 1996
> I guess you tried interger point format instead of floating point format
> when you run s.surf.tps. Try to change your site file format like the
> following:
> X|Y|%Z instead of X|Y|#Z
> if Z attributes are floating point. "#" is for interger.
> Jenny Z. Hou
When I use "%" instead of "#" , then
GRASS-GRID > s.surf.tps input=28 elev=28.1.tps dmin=1 zmult=1000
npmin=28
The number of points in sites file is 28
The number of points outside of region 0
The number of points used (after reduction) is 28
The region problem is be solution.
But ,when I saw the output rast file , the values are all zero!
What is wrong? Is the parameter wrong?
Wen-Yann
ov83609 at student.nsysu.edu.tw
