Networking in GRASS
Malcolm Williamson
malcolm at cast.uark.edu
Fri Jan 26 07:00:00 EST 1996
Hello, Evaristo
For one of the only raster-based networking discussions that I have seen,
refer to C. Dana Tomlin's _Geographic_Information_Systems_and_
Cartographic_Modeling_ (Prentice-Hall, Inc., 1990). A very good raster
analysis reference, in case you're not familiar with it.
-Malcolm Williamson
Malcolm D. Williamson - GIS Specialist E-mail: malcolm at cast.uark.edu
Center for Advanced Spatial Technologies Telephone: (501) 575-6159
Ozark Rm. 12 Fax: (501) 575-5218
University of Arkansas
Fayetteville, AR 72701
On Thu, 25 Jan 1996,
Evaristo QUIROGA wrote:
> Hello GrassGurus:
> We have been working for more than 3 years with GRASS. Until we have used it
> as a graphic database with plotting aim and simple analysis of overlay
> operations, proximity functions, spread functions and seek functions.
> Lately we have developed some models with the combination of the map algebra
> and unix scripts.
> In this line of progressive complication we have gone into the network
> problematic (transport of water through a system of irrigation channels,
> ordering of a river network, etc) and its resolution in GRASS environment.
> That's my question: How is treated the problems that implicate networking in
> GRASS? Have they to be solved only by means of combination of r.mapcalc
> instruccions in UNIX scripts loops? Have they to accomplish any intermediate
> step? Do the misterious, for me, cost maps and this asociate functions play
> any role in this point? And, would the run times of the network functions
> allow real time applications?
> As a first example of this problematic and other similars, here you are a
> case:
> We desire to improve the quality of our DEMs by means of incorporating
> complementary information to the contour lines, in the sites file to
> interpolate. This new information is of points type (3d vertex points) and
> linear type (stream networks, ridges, etc), which have been digitized from th
e
> same maps as the contour lines. We want that this linear information
> to be reflected in the created DEMs. The trouble is that vectorial
> information is 2D, it hasn't elevation. Here begin the problem:
> The stream and contour line vector maps are converted to raster.
> >From this maps, by means of the map algebra (r.mapcalc), we create a new map
> in which all the cells of the stream map that have a value different of 0 in
> the contour map take this value in the new map. Now we have a result map
> which have the elevation in the intersection of the streams with the contour
> lines. Later we have to fill in with elevation values the stream path in all
> its length. For this, in all the stream cells, we have to follow its path in
> the two senses, until the two nearest cells which have elevation value are
> found. The elevation value of the target cell is equal to the lineal
> interpolation along the river path of this two nearest cells with elevation
> value. The problem is how to find from a stream cell the two nearest cell
> with elevation value following the stream path in both senses. Could it
> be made with neighbouring loops? With networks functions?
> Thanks in advance.
> Evaristo.
> __ __
> / / Evaristo QUIROGA RAIMUNDEZ / /
> ___/ / ___/ /
> / / UNIVERSIDAD AUTONOMA DE BARCELONA / /
> \__/\\ Gabinete de Analisis Territorial y Ambiental \__/\\
> \\__ Unidad de Geodinamica Externa y Hidrogeologia \\__
> / /\ Edificio CS / /\
> \ / /\ 08193 - Bellaterra (BARCELONA) \ / /\
> \ / \ SPAIN - EU \ / \
> \___/ email: evaristo at cataw.uab.es \___/
