Help convert vector contour line to surface elevation
Gregg A. Hadish
gahadish at iastate.edu
Mon Jan 22 07:00:00 EST 1996
At 06:32 PM 1/19/96 GMT, you wrote:
>Dear Grassusers
>I have a set of vector contour lines that I would like to convert to raster
> surface elevation. If r.contour can create a vector contour file from
>raster elevation data, is there any command that I can use that will create
>raster elevation data from vector contour lines.
>Any suggestions or help are welcome.
>Cheers,
>Kamarul
First run v.to.rast on the vector, then run r.surf.contour on the new raster.
Gregg Hadish
