query longitude,latitute ?
Agustin Lobo alobo at ija.csic.es
Mon Jan 22 07:00:00 EST 1996
d.what.vect or d.what.rast will yield coordinates in the units defined
in your location. If you need lat-lon and you location was not defined
to use lat-lon, then you have to convert the d.what.vect or d.what.rast
output. If your location is in a UTM projection, use m.u2ll.
Hope it helps
Agus
Dr. Agustin Lobo
Instituto de Ciencias de la Tierra (CSIC)
Marti Franques s/n
08028 Barcelona (Spain)
tel. 34 3 330 2716
fax. 34 3 411 0012
alobo at eno.princeton.edu
