Needed: Raster or Vector map of Lower 48 states correction
Rick Thompson
rick at cast.uark.edu
Wed Jan 10 07:00:00 EST 1996
Hi John,
I need to correct the below. Under the location, make a PERMANENT mapset,
then untar at this level. Rick
> A file "US_lazea.tar.gz" is available on the cast ftp site: cast.uark.edu .
> Directory: /data/ftp/private/outgoing/US.lazea
> You can make a location direction and untar the file from that directory. Al
l
> necessary info (DEFAULT_WIND, etc.) is included. The projection is Lambert
> Azimuthal Equal Area.
