IDRISI to GRASS
Michel Wurtz mw at okawango.u-strasbg.fr
Wed Jun 5 08:00:00 EDT 1996
In article QAA15964 at camelot.es.anl.gov, sydelko at es.anl.gov (Pam Sydelko) writes
>Does anyone know how to import IDRISI files into GRASS?  I thought I saw
>something on this list server that mentioned a r.in.idrisi command at one
>time, but can't seem to track it down.
>Pamela Sydelko
>Argonne National Lab
With IDRISI 4.0 (DOS version), I used the following method:
On the PC running Idrisi
- if files are compressed, use "CONVERT" to uncompress .IMG on IDRISI
  (compressed files are not handled)
- in import/export menu run "GRASSIDR".  Export in  binary format
  this will create 2 dir (cell + cellhd), each containing a file for the
  same dir in grass data tree
On the unix machine running GRASS
- copy the 2 files created on your grass data tree
- if the size of the cell = 1 byte, its OK
- if the cell's size = 2 bytes, you must run
  "dd if=<file in the cell dir> of=<other name> conv=swab" (byte order is diffe
rent)
  and rename the resulting file to the original name.
- run r.support to verify header file (in cellhd) and add a color table.
In fact uncompressed binary .IMG files and uncompressed Grass files have same f
ormat
(except for byte ordering if cell are bigger than 1 byte) and as header files a
re in
ASCII, you can easely create with a text editor
Hoping this will help you,
Michel Wurtz - ENGEES, Strasbourg, France
