John, Yes, you need to have 80 column ascii dlg - an easy way to do this is to use the UNIX "fold" command. The "blowing up in PHASE 2" problem could be the v.support bug depending on how you got your source code - see: http://www.cecer.army.mil/grass/faq.html (question #9) good luck - - Bill
