GRASS under IRIX5.3
    David Wheatley
    D.W.Wheatley at soton.ac.uk
    Mon May 20 08:00:00 EDT 1996
Xin Zhuang wrote:
> try to rebuild GRASS under IRIX 5.3 but got the following errors:
> /usr/grass/src/src/libes/gis
>   make -f OBJ.sgi/make.rules
>         rm -f OBJ.sgi/gets.o
>         cc -O -DGETHOSTNAME_OK -I/usr/grass/src/src/include -DUSE_TERMIO -c g
ets.c
> cfe: Warning 709: gets.c, line 43: Incompatible pointer type assignment
>                 sigtstp = (int (*)()) signal (24 , catch_ctrlz);
> *** Error code 1 (bu21)
> Appreciate any hint and help
When I built GRASS under irix 5.3, I found that I needed to specify the -cckr f
lag
to the compiler to make it behave like a Kernigan and Richie compiler. I don't
know
if this is your problem, but you don't seem to have that flag set in your heade
r
file.
David Wheatley
Department of Archaeology,
University of Southampton,
UK, SO17 1BJ
