Undeliverable Message
    MAILER-DAEMON at cecer.army.mil
    Fri May 17 08:00:00 EDT 1996
To:
Cc:
Subject:
Message not delivered to recipients below.  Press F1 for help with VNM
error codes.
        VNM3042:  grassu-log at TR-S@USACERL
VNM3042 -- NAME NOT FOUND
   Mail cannot deliver the message for one of the
   following reasons:  the appropriate StreetTalk is not
   available; the recipient's user name was deleted; the
   recipient's name was not entered correctly.  Verify
   the accuracy of the name entered.  If the name you
   entered is a user name, check to see if the user was
   deleted. If the name is correct and the user exists,
   check the connections between the recipient and
   the sender.
   You may see this error if you send a message to a list,
   but one of  the names on the list is incorrect or invalid.
   Anytime a user is deleted, that user name must be
   removed from all lists that contain the name.
----------------------  Original Message Follows  ----------------------remote
execution       [uucp job mntc600Cb335 (5/17-8:22:50)]
        rmail mwirm!fjs
exited with status 1
        ===== stderr was =====
bad system name: mwirm
uux failed ( 11 )
rmail: Return to attmail!internet!isis.cecer.army.mil!owner-grassu
