ERROR G_calloc
Cosyn Bart Bart.Cosyn at rug.ac.be
Thu May 9 08:00:00 EDT 1996
> shutting down anything else that is running
> (netscape xv etc) usually that does the trick.
> If that fails changing to a coarser or smaller region
> might do it,  (some programs like r.watershed which use
> huge amounts of memory have a low (and slow) memory mode.
> These problems are likely to be more acute using the
> floating point version of GRASS because doubles are
> bigger than integers. So the G_calloc problem is
> likely to occur more often.
I will check your suggestions but to be honest I have it already on very
small regions and low resolution!
I need to check it in detail!
                Bart
