What exactly is Spatial Analysis ??
    Malcolm Williamson
    malcolm at cast.uark.edu
    Mon Nov 25 10:08:59 EST 1996
On Fri, 22 Nov 1996, Harini Nagendra wrote:
> On Thu, 21 Nov 1996, Malcolm Williamson wrote:
> > To me, "spatial analysis" implies analysis of a point or points using a
> > technique that considers spatial placement of data.
> Just wondering... why neccesarily only point data? What about continuously
> varying data, along a line for eg? If you want to look at the variation
> in such data along a particular direction then by your definition does that
> come under spatial analysis?
> Harini Nagendra
> Centre for Ecological Sciences
> Indian Institute of Science
> Bangalore - 560012
> India
Your "point" is taken. :) My definition was not meant to be anything
absolute; I was merely trying to help someone out. I would also argue
that any _analysis_ done in GRASS, anyway, is inherently calculated based
on points in space, regardless of whether the _data_ represents lines or
surfaces. Lines are composed of vertices, and surfaces are dynamically
resampled to a regular grid of x-y points in GRASS. Anyway, a theoretical
discussion of spatial analysis would be better suited to the GIS-L list.
Regards,
	-Malcolm Williamson
