Elevation data
Philip Verhagen
philip at raap2.ivambv.uva.nl
Tue Oct 15 05:20:42 EDT 1996
> I've got vectorial data representing isolines of territorial elevation
> and would like to generate an elevation map as is required for 3d
> display. There is no bounding rectangle, so r.surf.* fail. Is there
> another way to do this?
No real problem, I think. Digitize the area you want to have interpolated
in v.digit (basically, an outline of the isolines) and convert this to
a raster map that you use as a MASK during interpolation - if I recall
right, the area outside the MASK will not be interpolated.
Good luck,
Philip Verhagen
R A A P
Plantage Muidergracht 14
1018 TV Amsterdam
The Netherlands
tel: +31 (20) 421 62 00
fax: +31 (20) 421 42 90
http://raap2.ivambv.uva.nl/home_eng.html
